I have a Point of View 1GB GTX 550Ti and plan on buying a RX480 (not quite sure which and when exactly). My 550Ti will run for at least two more months and has overheating problems, so I wanted to reapply the cooling paste. Then I thought about buying a water cooler that I'll reuse on my RX480.
TL;DR: Is it possible to use the same cooler on a 550Ti and on an RX480?
https://linustechtips.com/topic/657533-reusing-water-cooling/
No, different chip locations.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/657533-reusing-water-cooling/#findComment-8502843
2 minutes ago, glunday said:
not unless you get one of the cheap "universal" ones that are basicly a CPU AIO cooler and rig a mount for it. but you should just try reapplying the paste and see if that can tide you over.
Yeah, guess I'll have to do it. I just thought I may be able to already buy the proper water cooler because I have to buy the paste anyway.
Thanks for the answer.
https://linustechtips.com/topic/657533-reusing-water-cooling/#findComment-8502883
the paste is like 5$ at my local store and i can find it online for 1$
i7 6700k - Asus ROG Strix GTX 1080 - assorted other stuff
https://linustechtips.com/topic/657533-reusing-water-cooling/#findComment-8502903
