looking for a CPU cooler for my new build. I'm not THAT fussed about specific degree performance, if they are in 10C of eacother then I'm fine with them, however I was stuck on some things :
First, I can't seem to find a high performance air cooler that doesn't look like a huge, ugly metal block. I liked the look of the dark rock pro 3 until I saw how massive it was, it blocked out the RAM and nearly touches the graphics card.
However, on the side of watercooling , I love the look of them aswell as having, let's admit it, better performance. Obviously, there is a risk of destroyed builds, however  I'm not bothered about my build bieng destroyed if it leaks if I go with something like Corsair AIO coolers, as they offer RMA for 5 years on watercoolers and will replace any damaged components should the cooler leak. I would be glad going with a watercooler , but are their any companies that do the same as corsair? I like the look and price of thermal-take and deepcool AOI coolers much more then corsair, especially since I have experiance having a shitty corsair AIO cooler with it's loud fans, but i'd rather pay more and get a worse product through Corsair if it means my components are safe. What  AIO cooler should I get, do other companies have reliable customer service?
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/657501-cpu-cooler-help/
1 minute ago, Pgat3000 said:
It depends of your budget, but i will recommend NZXT Kraken X61
Thanks for reply, there isn't really a budget but i'd rather save. I could spend up to £100 ish that's my topping point
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/657501-cpu-cooler-help/#findComment-8502550
i have a corsair H100i (the older one with shiny plastic not the newer one) i bought it refurbished from corsair and they gave me the full warranty, had it for 2 years running in both intel and amd machines no problem, while i've never had the liquid cooler fail i have had a keyboard and they just had me describe what was happening and send a picture, didn't even have to send it back before i got a replacement in the mail. in my opinion if you only want to cool a cpu an AIO cooler is the way to go. and corsair support cant be beaten.
i7 6700k - Asus ROG Strix GTX 1080 - assorted other stuff
https://linustechtips.com/topic/657501-cpu-cooler-help/#findComment-8502553
7 minutes ago, Armakar said:
SNIPS --- Obviously, there is a risk of destroyed builds --- SNIPS
I rarely heard about off the shelf water coolers that start leaking; anyways I think that some of them cover with warranty if they damage other components.
As a suggestion, Corsair, NZXT, Cooler Master
DESKTOP PC - CPU-Z VALIDi5 4690K @ 4.70 GHz | 47 X 100.2 MHz | ASUS Z97 Pro Gamer | Enermax Liqmax II 240mm | EVGA GTX 1070Ti OC'd
HOME SERVER | HP ProLiant DL380 G7 | 2x Intel Xeon X5650 | 36GB DDR3 RDIMM | 5x 4TB LFF Seagate Constellation 7.2K | Curcial MX500 250GB | Ubuntu Server 20.04
https://linustechtips.com/topic/657501-cpu-cooler-help/#findComment-8502560
