Help me achieve stable overclock
Solved by dragoon20005,
are you talking about the FX8350 here?
if yes
i think i may have found your problem
the mobo is not able to support the FX 8 cores with the power draw which is why the CPU is getting throttled here by the VRMs overheating.
you either need to downclock the CPU or you need to replace the mobo to a better one
the GA-970-UD3P is the better board with better VRMs
