So, with the new intel SSDs out, I'm thinking about getting one.  My CPU only has 16 PCI-e lanes, and this takes up 4.  Is there a way to use this and my graphics card?  Thanks!
GPU: ASUS Strix GTX 1070,  CPU: i5-6600k OC to 4.0 GHz,  PSU: Rosewill Capstone G750 750W,  Mobo: MSI Z170A Krait Gaming,  Case: NZXT H440 White,  Memory: G.Skill Ripjaws V 16GB (2x8),  HDD: Seagate Barracuda 2TB, Mouse: Razer Ouroboros,  Keyboard: Razer BlackWidow Chroma, Mousepad: Razer Overwatch KB+M pad, Headset: Corsair Void RGB,  Monitor: 1x ASUS PB277Q 27" 1440p & 1x HP Pavilion 25cw 25-inch 1080p
https://linustechtips.com/topic/656626-m2-help/
3 hours ago, Electronics Wizardy said:
It uses the pcie lanes from the chipset, so your gpu is still running at 16x
So, I would be fine, right?
https://linustechtips.com/topic/656626-m2-help/#findComment-8488953
Yep, and also gpu's will perform about the same at 8x or 4x
Ok good to know, thanks!
https://linustechtips.com/topic/656626-m2-help/#findComment-8488965
11 hours ago, AlphaPolack said:
If the system in question is the one in your signature, you are fine.
The Z170 chipset has 20 PCI 3.0 lanes
Yes, it just happens to be. xD Thanks!
https://linustechtips.com/topic/656626-m2-help/#findComment-8499340
