Long story short. I just bought an EVGA GQ 650w PSU and want to replace my old prebuilt systems PSU until I get the rest of my system is this a bad idea with older hardware and a new PSU. I know it's stupid but just want to be sure before I blow up my prebuilt.
Thank You,
https://linustechtips.com/topic/656493-quick-power-supply-question/
Thank You,
Also the prebuilt is an Dell precision t3400
Would not say it is stupid for asking.
Anyway should not be a problem aslong as you can connect everything proper with your new PSU. A good PSU can survive several builds and upgrades. My own PSU is near 10 years old and still works. But only reason I want to replace it currently is that I no longer need 1000W since stuff ain't that hungry anymore + the looks and even more silent operation for the new PSU might come into play. 650 is for most systems more then enough.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
Just now, Electronics Wizardy said:
Should work fine, the older psu won't hurt anything.
I wouldn't upgrade the psu unless there is a problem with it. The psu's built into these workstations are very good and enough for a good gpu.
I am only doing it because I upgraded the CPU and GPU and also Added more RAM I think the PSU is close to maxing out at its 375w capacity.
The psu is more than big enough. Id keep the old one.
Ok thank you!
5 minutes ago, kindlestone said:
Ok thank you!
Looking at photos of the Dell's motherboard, you should be able to plug the new PSU into the correct connectors. If they fit just fine that means they're electrically compatible.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
