My first Build
Go to solution Solved by Energycore,
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  (£293.88 @ Aria PC)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  (£17.99 @ Ebuyer)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  (£127.43 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (£74.99 @ Amazon UK)
Storage: Kingston FURY 480GB 2.5" Solid State Drive  (£95.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£42.99 @ Ebuyer)
Video Card: EVGA GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card  (£399.99 @ Ebuyer)
Case: Cooler Master Silencio 652S ATX Mid Tower Case  (£93.69 @ CCL Computers)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£70.97 @ Amazon UK)
Total: £1217.92
Generated by PCPartPicker 2016-09-07 15:43 BST+0100
Save buck on the SSD so you can get that juicy juicy 6700K.
Don't be deceived by the CPU cooler, it's better than a 212 EVO + cheaper.
This PSU is way better.
ok, so as the title says this is my first build ever and basically i just wanted someone to give it a quick check over to see if i have created any bottlenecks or gone with overkill items in any places. i would use this pc mostly for gaming and would like it to be fairly quiet and run cool even when overclocked. ideally it could be upgraded in the future
http://uk.pcpartpicker.com/list/hhXFgL
https://linustechtips.com/topic/656287-my-first-build/
swap the NEX for a better unit, it performs badly. if you're playing in 1080p 144hz, get an i7 instead as the 6600k will bottleneck. also, you can get the cheaper and similar performing cryorig m9i for 10 pounds less. otherwise its fine.
https://linustechtips.com/topic/656287-my-first-build/#findComment-8480844
i7 is no needed if he doesnt play at 1080p 144hz, because i5 wont bottleneck if he doesnt playat 144hz
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/656287-my-first-build/#findComment-8480957
i5 gets much more stuttering compared to an i7 and gets 5-30 fps lower performance in games.
guy's i5 4670 maxes out at 100% with a gtx 1070 while his friend's 3770 is at 60-80%
i believe that there are other veteran members who can attest to i5s bottlenecking in 1080p 144hz too.
https://linustechtips.com/topic/656287-my-first-build/#findComment-8481022
but its 100$ more expensive and for gaming its not worth...
https://linustechtips.com/topic/656287-my-first-build/#findComment-8481037
when you're playing at 1080p 144hz you'll want every frame you can get, otherwise there will be no point getting that higher refresh rate anyways.
https://linustechtips.com/topic/656287-my-first-build/#findComment-8481064
then just let him get a 980ti, it will support 144hz i guess
https://linustechtips.com/topic/656287-my-first-build/#findComment-8481162
he's already getting a gpu with the performance of a gtx 980ti. my point is that he should get an i7 to fully utilise the 144hz refresh rate, which he would not be able to utilise as well with an i5.
https://linustechtips.com/topic/656287-my-first-build/#findComment-8481203
Total: £1217.92
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/656287-my-first-build/#findComment-8481220
Upgrade the Power supply to a G2 if you are staying with EVGA or check out this thread for PSU guidelines.
And don't worry about the 6600k "bottlenecking" a GTX 1070. Spend the difference on a 240 AIO cooler and Overclock the CPU.
Storage:  I would ditch the samsung 850 and go with a Samsun SM 951 256GB M.2 running in PCIe Mode.  Then Later purchase the Evo SSD in a holiday sale.
Emerald Shade: i7-4790k -  2x360rad Custom Water Cooled Loop  - MSI Krait SLI - Corsair Vengence Pro 2x8gb 2400 - OCZ RD400 512Gb - Samsung Evo 850 250Gb - 2x Seagate Barracuda 3Tb HDD - EVGA 1080 GTX FTW DT - InWin 303 - EVGA G2 850 - Win 10
https://linustechtips.com/topic/656287-my-first-build/#findComment-8481371
first off thanks for the quick and helpful reply's.
taking into consideration what has been said i decided to go for the i7-6700K over the i5-6600k mostly for future proofing of the system. a better power supply (650W so i could maybe go SLI down the line) and the Kingston Fury 480GB SSD.
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£79.99 @ Amazon UK)
Total: £1226.94
Generated by PCPartPicker 2016-09-07 16:23 BST+0100
hopefully i dont look like to much of an idiot haha
https://linustechtips.com/topic/656287-my-first-build/#findComment-8481772
