Ultra budget build help
1 minute ago, kittenmetal said:There is no harm in doing a slow build/buy method, if you have a steady budget set each month. - My Current Build was built in a manner very similar to this, plus it allows you to adjust for new technologies in the process. but build up your wishlist and write the parts down, and go price hunting!
say your monthly Budget for your new build was $150 -
Month one September -
New PSU https://www.amazon.com/EVGA-BRONZE-Warranty-Tester-100-B1-0700-K1/dp/B018JYHBE6700w EVGA PSU ($53)
https://www.amazon.com/Samsung-750-EVO-2-5-Inch-MZ-750250BW/dp/B01AAKZRP2
250GB Samsung SSD $70
Plus all your other little bits and bobs people often forget like the thermal paste, cable ties etc. as you will have about $20 spare
Month Two $150 October -
if you saved that $20 instead you can get your Motherboard (there may be others out there) - (I am an AMD Entusiast so not up to speed with the new Intel Technologies but this appears to be compatible with Skylake Processors) See if you can find it somewhere else for sale (I don't like Ebay!)
http://www.ebay.com/itm/ASUS-Z170-P-LGA-1151-Intel-Z170-HDMI-SATA-6Gb-s-USB-3-0-ATX-Intel-Motherboard-/122055649247?_trksid=p2141725.m3641.l6368
Month 3 $150 November -
https://www.amazon.com/2133MHz-PC42133-Desktop-HX421C14FB2K2-16/dp/B01HI14AZ4
DDR4 Ram - $77
Save the Rest of the Dosh for Black Friday deals...
Month 4 December $150 + $63 Saved from November ($213)
Unknown Price but this is where the Black friday Deals come in when looking for that new Skylake Processor they are not cheap but there will be plenty on offer over the course of that weekend...
and Any other bits you need that you can get on deals and from the $213.
Month 5 January (if you have anything left over from christmas!)...
I am not going to carry on with this, but this is how I generally build my PC's because I am in a very similar position to yourself with a whole £100 Luxury cash only each month after bills and such. THis would be my advice if you really must get the build going now. - just make sure you have somewhere safe for all the boxes...
Something that I should start on then, It shouldn't be to hard to do this.
Now I just need to see If I can trade my now overheating craptop at the pawn shop for a temporary desk top so we can watch stuff again.
