Im new to this , i had a Gtx 950, 8 gb RAM, a i5 6600(not k) and bought a 500w EVGA 80 + bronze. The thing is it didnt booted up. i tooked to the pc guy at the bank my dad works on and he said that all burned because the wattage wasnt enough for the gpu ,that i needed like a 800 w psu. Is that true?? Cause i looked in lots of websites and i found out that i only neede 90w for the 950!Plz help mee!! :(:(
https://linustechtips.com/topic/655981-help-me-some1-plzzz/
Not just anybody! HELP!
That guy is an idiot and no wonder he works at a bank. Are you sure you plugged everything in?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/655981-help-me-some1-plzzz/#findComment-8472449
3 minutes ago, CubisticWings4 said:
I would definitely check the RAM.
If it is ECC (Error Correcting) RAM on a non-ECC motherboard it's probably not gonna work.
Do you have the motherboard model number?
i knew it but i will look for it now
https://linustechtips.com/topic/655981-help-me-some1-plzzz/#findComment-8472509
3 minutes ago, AlvaroEstebanez said:
And my ram was Silver and some people said that it was server ram PLZ HELP
ECC RAM will usually still work in a board that doesn't support it. Registered RAM will not work since they have extra pins.
https://linustechtips.com/topic/655981-help-me-some1-plzzz/#findComment-8472512
Just now, CubisticWings4 said:
You're right! Thanks for correcting me.
Common mistake. People confuse registered/buffered with ECC.
https://linustechtips.com/topic/655981-help-me-some1-plzzz/#findComment-8472542
Probably something not plugged in or some wires might be busted (which sometimes happens, depending on your cable management).
First thing you can do is try to start it up without the GPU, see if it works.
If that doesn't work, then make sure the PSU works on an already working PC, check the cables for any tears.
Check the RAM on an already working PC.
If those 2 work, check CPU on an already working PC.
If everything works, then it's definitely the motherboard.
It might not be your fault at all, things tend to break. I had a MB breaking on me out of the box.
https://linustechtips.com/topic/655981-help-me-some1-plzzz/#findComment-8475841
ill try that
https://linustechtips.com/topic/655981-help-me-some1-plzzz/#findComment-8485453
its an ASUS P8H61-M LE/CSM R2.0 LGA 155 INTEL H61 MICRO ATX
https://linustechtips.com/topic/655981-help-me-some1-plzzz/#findComment-8485482
