Here in the next weekend, I'm gonna try to get my old PC running on it's feet again. I will continue to upgrade it as time goes on, like a new case. But I won't get anything until next weekend. Until then, here are the current specs:
Slot 1 Pentium 3 @ 500MHz (100MHz FSB, 512KB cache, 250nm) "Katmai"
Intel WS440BX "Warm Springs"
3dfx VooDoo 3 3000 AGP (AGP 2X, 166MHz, 16MB, 250nm)
512MB Kingston ValueRAM (256x1, 128x2; PC100)
Seagate Barracuda ATA IV (40GB, ATA-100, 7,200RPM)
I will replace the hard drive with a Maxtor DiamondMax Plus 8 40GB (and maybe have 2 instead of just 1) since the Barracuda is just about dead.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/65507-project-voodoo/
I don't recognize any of these parts.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/65507-project-voodoo/#findComment-894922
Voodoo... Collectors edition. Keep it.
Come to think of it, this pentium will be worth something too after 20 years xD:)
Trust me. I will NEVER get rid of my electronic baby. If my mobo will let be, I'll retire the VooDoo and try my luck with an FX 6200.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/65507-project-voodoo/#findComment-898962
Ahh PC100...those days :P
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/65507-project-voodoo/#findComment-899176
I may be 14 (November 4th and I'll be 15! :D) but here a couple months ago I checked and I had about 30 PC100 sticks (mostly 64MB). Needless to say I got rid of them. And no, not in the trash.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/65507-project-voodoo/#findComment-899188
I'm thinking about getting this case for it: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119267
What do you guys think? I was trying to make it look cool, but inconspicuous. If not, I'll put it in my old case.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/65507-project-voodoo/#findComment-900087
Lulz I used to run that same CPU back in the day. Man if you had 512 MB of RAM back when those components were relevant that would've been huge. Also I think you should get a case from the time if possible i.e. something beige.
Beige would kinda mess with the rest of my stuff, since everything else is black. But, I can't really use a case with from USB or audio, so do you know of one like this?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/65507-project-voodoo/#findComment-900532
this will be a good thread.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/65507-project-voodoo/#findComment-900569
lol Thanks. Right now though it's sitting, naked on my desk, begging for me to rebuild it.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/65507-project-voodoo/#findComment-900602
make sure you take lots of pics and try cable management (even though it might be harder in an old case)  :D
Rig Specs:
https://linustechtips.com/topic/65507-project-voodoo/#findComment-900633
Get a 900d to showcase it.
If I had money falling out where the sun don't shine and it didn't have front panel connectors, I would love to.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/65507-project-voodoo/#findComment-900704
I have that case (with the silver and the windowed side) it works lol but the Cooler Master Elite 430 is much nicer: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
i have used both cases and the 430 is far nicer and just add a PSU with it for like 20 bucks and will be the same price really
https://linustechtips.com/topic/65507-project-voodoo/#findComment-900760
Fantastic to see that I'm not the only one that still owns hardware like this, it all seems to be a generation or two newer than mine though (Pentium 2 233mhz and Creative 3D Blaster Banshee for PCI). :D Can't wait to see how this turns out, I really hope you choose a retro case for it. :)
https://linustechtips.com/topic/65507-project-voodoo/#findComment-903001
I ran into a bit of a problem. My hard drive dropped out, so I'm guessing something moved when everything was sitting on top of my old Dell (for testing it). Darn.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/65507-project-voodoo/#findComment-933477
