So, I can't seem to figure why my program doesn't work. It should receive a 4bit binarial number by portA and display it through portB coded for a 7 segment display, using RA4 and RA6 to turn the displays on, but I only get both displays on and 88 getting display, and a short If I put any bit on
TP6.asm
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
https://linustechtips.com/topic/654982-assembler-help/
In "inicio":
	movlw	h'01'
	movwf	TRISA
Moves literal hex value 01 to TRISA. In binary this is 00000001, thus this makes RA0 a input and all other PORTA pins outputs. This is probably not what you want if you need to receive a 4 bit value on PORTA ?
In "principal":
movlw	PORTA
movwf	temp
MOVLW means "Move literal to W" thus the above instruction moves the literal value "PORTA" (h'05' - the memory address of PORTA) to W, not the contents of PORTA. To copy the contents of PORTA to W use:
MOVF PORTA, W
MOVWF TEMP
https://linustechtips.com/topic/654982-assembler-help/#findComment-8425022
21 hours ago, Unimportant said:
In "inicio":
	movlw	h'01'
	movwf	TRISA
In "principal":
movlw	PORTA
movwf	temp
MOVF PORTA, W
MOVWF TEMP
Thanks dude! I'll test it tomorrow and advice you!
https://linustechtips.com/topic/654982-assembler-help/#findComment-8472800
