Should look at the new ML120/140 fans from Corsair. The white LED ones are sexy.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/654609-whiteblack-case-fans/#findComment-8399515
Where are you using the fans? Where are you shopping/located? Budget?
https://linustechtips.com/topic/654609-whiteblack-case-fans/#findComment-8401923
