I am tossing up between a 27inch 1440p Or 29inch 1080p 21:9. Will Have My Old 24inch 1080p As My 2nd Monitor help plz :)
Solved by Streetguru,
6 minutes ago, willie420 said:Like i said i don't really game anymore and I'm more about tv shows movies tube etc so i 100% do not want a tn panel and thus really don't not care about 144hz. but yes its a very good point for someone who's is looking to game a lot which i am not. My 24 inch i have is 120hz but I'm happy to go down for a petter panel for video viewing.
Then 1440p 60hz because you can just fit a 21:9 1080p display worth of pixels inside it for movies
or just save up and go for 4k
Walmart has cheap 4k TVs right now, 49" 4k for $299, the upscaling on it isn't too bad either, and then you can check out some 4k video
