Can you see the drive in windows explorer?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/654435-iso-problems/#findComment-8397887
Just now, Stevoisboss said:
Correct
Try reformatting it in disk management.
PSU Tier List | CoC
https://linustechtips.com/topic/654435-iso-problems/#findComment-8397892
Sandisk USB drives are known to not be recognised by the windows media creation tool...download windows 10 using the DVD option (as you get to choose where it's downloaded to) and use another tool to put the windows 10 ISO onto the drive :D
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/654435-iso-problems/#findComment-8397966
