Here is my current plan - http://uk.pcpartpicker.com/list/tj2cbj
The Asus Maximus VIII Impact only has a single USB 3.0 connection but manual says its two ? , my case will need two for the front but
I will also need a internal USB connection for the CPU liquid cooler to use the corsair link.
What am I supposed to do so that everything works :L
Also any suggestions towards my build?
PS - Its currently 4:09 in the morning and Iv not slept, am about to collapse. Sorry if I am not making sense, but Iv just been planing to build this PC for over a week now and its just stressing me out D:
PPS (PSS?) - how many fans can I stick in there
https://linustechtips.com/topic/653957-usb-issue/
Dominator Platinum is just a fancy name brand
Also, why you sticking an ITX board into an Matx case?
Edit: I just saw that the case is pretty much meant for ITX but can fit an Matx- rip
https://linustechtips.com/topic/653957-usb-issue/#findComment-8394030
That CPU's maximum supported DDR4 speed is 2133mhz according to ARK ( http://ark.intel.com/products/88195/Intel-Core-i7-6700K-Processor-8M-Cache-up-to-4_20-GHz ). You may want to get slower (and cheaper) memory, unless you intend to get into overclocking.  And you do not need 32GB of RAM to game. 8GB is sufficient, 16GB is the most you will ever need.
https://linustechtips.com/topic/653957-usb-issue/#findComment-8394057
You're spending too much on premium components that don't offer significant performance increase.
Here's a cut down version of your build: http://uk.pcpartpicker.com/list/Vh73yf
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/653957-usb-issue/#findComment-8394061
