As the title says i am getting horribly low FPS in BF1
Also is there a way to limit the game to 30FPS so i don't get horrible frame drops!
My Important Specs Are:
Intel Pentium G3258 (2Core 2Thread) 4.7Ghz
AMD XFX RX480 8GB
Kingston KVR 1333 4x2GB Kit
Which part is the problem because in game i'm seeing everything at 100%
That includes the RX480 at 100%, the CPU and the RAM is around 7/8GB
(P.S This is at minimum 1440x900 60Hz)
(P.P.S Can someone plz find a fix <3 thanks)
https://linustechtips.com/topic/653937-bf1-low-fps/
Probably CPU bottleneck is not utilizing your gpu fully. I mean what can you expect out of a dual core $70 processor. Pair that RX480 up with a I5 and you can play whatever you want maxed
[CPU: 4.3 GHZ I5-4670K] [MB: Gigabyte Z87-D3H] [RAM: Corsair Vengeance 1833 MHZ (8GB)]
[GPU: Gigabyte G1 Gaming GTX 1070] [PSU: Corsair CX-750] [Cooler: Hyper 212 Evo]
[Storage: 2TB 7200RPM HDD / 500GB Samsung 850 EVO ] [Case: ThermalTake Chaser-MK 1]
[Keyboard:Corsair K70 RGB Cherry MX] [Mouse: Razer DeathAdder] [Monitor: 2 x ASUS 24 INCH IPS (1440p Soon)]
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8393862
AMD XFX RX480 8GB
Can you buy a Xeon 1231 v3? It'd be the best bang for you buck right now.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8393884
Just now, DisconnectedYT said:
Im already planning to buy that exact CPU in December for $369 AUD
That's what I would do. Can you reinstall the game on a different drive? I would also check AMD's beta drivers.
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8393900
Im running second newest driver and its on my Samsung 830 EVO (Which placed in the top 99% on Userbenchmark with a 696MB/s Read and 456MB/s Write)
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8393913
8 minutes ago, tp95112 said:
it is your cpu then.
Before my PC went stupid and gave me no FPS in any game, BF1 ran horribly anyway with potato graphics. I think it's a glitch more than his CPU being the problem. With the graphics settings I had the game on I would be getting 160 FPS in a different game.
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8393924
Id still say its a cpu issue. Bf1 being able to utalize cpu and gpu fully. The gpu is binned at 100% so it cant be a issue of anti aliasing being enabled or off
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8393960
My 4790K and 1080 are getting 40 fps. It's a buggy beta, but lowering the Res Scaling fixes it for some.
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8393969
These bugs are par for the course for EA and DICE.
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8393995
My Steam server (through VM) is getting about 70 fps when all Titans are allocated to it. Wow! Even BF3 has better fps... even though I'm in the concrete...
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8394035
2 minutes ago, tp95112 said:
What was your res scaling set to at first?
When installing BF One? The res scale on the server was set to 200% same as on my desktop. I play on triples 1080@60 and set everything to Ultra and res scale to 100%. Once I had the issues worked out I started getting about 60... b/c of frame cap.
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8394091
Yeah it shouldnt have been set to 200% thats weird. It was set to 42% for me when I started it
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8394096
I wonder if the game auto-calibrates?
I'm at the office so I only have the server at home. Can you check if Ultra sets the res scaling to 200%?
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8394103
It stayed at what ever I had it set to. It didnt auto set it to 200%. Weird yours was set to 200%
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8394184
Wife was using my VM since she forgot her password and set it to 200% since she just uses the single panel.
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8394187
I did that exact upgrade, though my G3258 was at 4.4 GHz, and it's a night and day improvement. You'll finally see what your RX 480 is really capable of (and it's capable of a lot, it's an awesome gpu). I'm running the Xeon E3-1231v3 with a GTX 970 and I get 70-80 fps in the BF1 beta at 1080p ultra. I imagine you'll probably do a little better than that once you get your new cpu since BF1 is likely to be an AMD sponsored game. You're getting hammered by your cpu, the beta splits the cpu load pretty evenly among the 8 threads on my E3-1231v3. I'm also always at full gpu usage, so with a better video card I should be able to get way more fps with the E3-1231v3.
https://linustechtips.com/topic/653937-bf1-low-fps/#findComment-8394196
