Ok so on my hackintosh i keep getting errors on the install such as "cannot be installed on your computer" "cannot attach disk image" I've downloaded a fresh copy of OSX 10.11 about 9 times now (downloading it for the 10th time) and unibeast 5 times and i keep getting these errors, i search the tonymacx86 forum and nothing was there that helped me i was hoping i could get help from the linus tech tips forum. Thanks
Edit
https://linustechtips.com/topic/653768-mac-osx-pc-problem-help/
Just now, Electronics Wizardy said:
What hardware are you using?
Where and when do you see these errors
after i click the drive to install on and then i see the error pop up, at the screen where the bar going across the screen showing how long before it's finished installing osx
https://linustechtips.com/topic/653768-mac-osx-pc-problem-help/#findComment-8392425
Still What hardware are you using?
Try a different usb.
https://linustechtips.com/topic/653768-mac-osx-pc-problem-help/#findComment-8392430
 Did you format the drive?
Made it a GUID Parition and set it to Mac OS Extended?
https://linustechtips.com/topic/653768-mac-osx-pc-problem-help/#findComment-8392437
i made sure of everything but it kept getting the error no matter how many times i redownloaded the OS i'm currently making a 10th unibeast bootable drive
https://linustechtips.com/topic/653768-mac-osx-pc-problem-help/#findComment-8392443
Before I make another comment, can you clarify something.
Are you getting the error when you're making the bootable drive, or are you getting the error when you're trying to install it onto a computer.
https://linustechtips.com/topic/653768-mac-osx-pc-problem-help/#findComment-8392463
trying to install it onto the computer
https://linustechtips.com/topic/653768-mac-osx-pc-problem-help/#findComment-8392488
Guest
