Alright so i downloaded battlefield 1 open beta. My quite old system ( 4 years i think ) can surprisingly handle it pretty well....
Until i found out that it freezes every now and then ( around every 30 seconds-1 min ) and once i check temperatures my cpu is all the way up to ~90°C which i know is not good
IT is i5-3570K with cooler that came with it (stock cooler) .... it's socket is 1155 so i probably need to upgrade cpu cooler but to which one ? is hyper 212x evo good enough ?
GPU: GTX 1060 6GB
RAM: 16GB HyperX RAM
CPU: R5 3600
Motherboard: ASRock B450 Fatal1ty gaming K4
OS: Win 11 Pro 64-bit
https://linustechtips.com/topic/653470-overheating-cpu/
also, would it fix any temps if i do cable management properly and clean some of the dust from cooler (there's not much dust but there is a little )
GPU: GTX 1060 6GB
CPU: R5 3600
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389333
well, unless your OC'ng your cpu, that stock cooler should suffice (depending on whether or not you have adequate airflow to disperse the heat being radiated by the cooler).
To answer your question about whether or not you should clean you rig up, and remove dust and what not....YES! if you think you can remove your stock cooler, and blow through the aluminum heat sync, and chunks of dust fly off.....YES!!
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389348
I don't know why you would use the stock cooler with K CPUs since their purpose is overclocking. What is your budget for the cooler?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389350
1 minute ago, AlwaysFSX said:
Cable management doesn't effect temps, have you replaced the thermal paste for the CPU since you built the system?
changed thermal paste like december last year
GPU: GTX 1060 6GB
CPU: R5 3600
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389357
cause as i said i bought it 4 years ago when i knew nothing about pc's so it was a prebuilt... and in pretty much all pre builts they give you stock cooler even if it is K cpu. My budget is like 30-35$ MAXimum. My cpu is not overclocked yet but i would maybe even consider it if i had a better cooler
GPU: GTX 1060 6GB
CPU: R5 3600
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389361
if he looks at his rig, and says "maybe i should clean those cables up", then its prolly bad enough that it could be blocking airflow throughout. maybe?
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389363
it is pretty bad ... it doesn't really go close to fans but i can see it increasing the temps in case itself
GPU: GTX 1060 6GB
CPU: R5 3600
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389367
Welp, maybe change it again and dust the cooler, see how your temps are after that.
Agreed. OP, like i said before, if youre not OC'ng your cpu (at least with intel) your stock cooler should be sufficient. but taking a microfiber cloth and some 99% propylene alcohol to the plate and reapplying some thermal grease should help. possibly. at least it wont hurt it.
For sure dust everything out...including the find on that cooler
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389372
i meant fins, not find lol
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389377
ok i will try and catch some time to apply thermal paste and clean some dust off from those fans thanks for help :D until i do that i wont really turn on bf1 coz i dont want to burn my pc and house on fire
GPU: GTX 1060 6GB
CPU: R5 3600
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389384
haha, completely understandable.
what program are you using to monitor your temperatures with?
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389389
speccy and a few other .. if you think its not trustable program you can suggest me something else :P
GPU: GTX 1060 6GB
CPU: R5 3600
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389392
are you running the free or paid version of speccy? not that i would know the difference between the two because ive never used it, but i seen it has a few extras that come with the paid version.
Personally, for me, i use CPUID. Although ive been told that its a reliable program, i still use my corsair link program for myliquid cooler, and it tells me a different temp than what CPUID does.
im not saying that speccy isnt reliable, mainly because your game should freeze whether or not speccy is installed. well, it SHOULDNT be freezing, but the no monitor program should have an affect on your game freezes
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389414
will see all once i clean it and stuff
GPU: GTX 1060 6GB
CPU: R5 3600
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389423
No.
hmm, i will def take a min to watch that here in a few. thank you.
But lets say for example, you have a HDD bay in front of your front intake fans. logically, being that there is an obstruction in the way, the air cannot move in the path of least resistance, making it harder to cool vrms and expel hot air.
i would think that if you had a JUMBLE of cables that looked like "poison ivy" from batman lived in the rig, there would be an obstruction that would lead to at least a few degrees in temp difference.
Im not arguing, just thinking, friend.
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389430
Tests have already been done by LTT, you need to literally fill your case with boxes and shirts to get any noticeable temperature effects. Having bad cable management or a hard drive cage in front of a fan does nothing to your temperatures.
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389451
What about components that done have a cooler on them? like the resistors on the mainboard and things like that? does this mean that as long as im not OC'ng, i can just use the stock cpu cooler and the stock gpu cooler, sin chassis fans?
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389471
Those components which are passively cooled only need a minimal amount of any airflow to keep them within reasonable temps, even filling your case with t shirts and boxes won't cause those components to overheat if you aren't overclocking. Overclocking is up in the air though, though I wouldn't try to do a worst case scenario with my case airflow for that. ;)
Stock though, it's fine.
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389481
NICE! i love learning something new.
i was wondering why my my cpu temps were hitting 8c during idle. lol (so many fans, and the h100i v2)
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389492
Yep, it's amazing how much really doesn't matter when it comes to computers. :D
https://linustechtips.com/topic/653470-overheating-cpu/#findComment-8389495
