So.....I have a Raspberry Pi 2, and 3, and I have a little USB Mic dongle thats really small factor (https://www.amazon.com/gp/product/B00IR8R7WQ/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1)
and i was wondering if there was a USB Auto dongle that was roughly that size, or slightly bigger? i dont really know what to look for some maybe someone has an idea? im not looking for an adapter to plug in
audio jack headphone or whatnot. I want the USB to have its own audio output so i dont have to worry about headphones, or external speaker systems.
Objective of project,
A mobile AlexaPi program (already have it, just cant take it anywhere since speakers are bulky and go through the on-board audio-jack)
https://linustechtips.com/topic/652851-audio-usb-help/
If your problem is the size of the connectors you can do what I've done and remove the connectors and solder directly to your board. I cut off the male port on a male to female USB cord. Then I connected the male port the the male wires on the Raspberry Pi.
Soldering your connections will give you a lot more room.
You can check out my build ( need to make a new video), but if you seen inside, the cords wouldn't fit so I removed some of the connectors (that are for prototyping)
https://linustechtips.com/topic/652851-audio-usb-help/#findComment-8385767
