System build with older PSU
Solved by STRMfrmXMN,
Ultra has like one series of PSUs that doesn't suck. I'd replace your PSU. You don't need to spend an arm and a leg since you have a 470 and it's heat-light and doesn't need lots of power. Honestly, an EVGA 600B or Corsair CX500M would do, though if you want a super solid PSU for your system then an EVGA GQ/B2/GS/G2 will do. The 550W version of the GS and G2 are fine, the 650W of the GQ, and the 750B2.
