1 minute ago, jonnylaw13 said:
im wanting to replace my power button with a toggle switch, potentially a double  throw for power and reset but i have a question. do i want to use a momentary switch or a standard push/pull on off switch?
For both you will ideally want a momentary toggle switch.
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8382211
that was my thought but i wasnt totally positive of what sort of switches were used. if i were to use a lighted toggle would it be suggested to use the power light for the light in the switch?
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8382255
If you were to use regular on/off toggles you would basically have to manually throw them back every time or it would be the equivalent of pressing and holding the power button. As for lighted toggles switches it depends on the switch as some require auxiliary power or will be power form the incoming circuit, but that usually requires 12V.
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8382293
im thinking separate LEDs for power and HD since i am unable to find let tipped momentary toggles, but now im also finding loose LEDs difficult to find. that search may lead me to a B&M im thinking
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8387097
If you are just looking for regular 3 or 5mm LED's they are fairly common and can easily be wired up to the front panel headers for power and HDD LED's.
https://www.adafruit.com/products/754
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8387161
Adding a standard switch wouldn't be an issue as long as you have a momentary button next to it on the same circuit.  So the toggle provides the connection to the momentary button which when pressed will turn on the computer, if the toggle is off the momentary button won't turn on the machine.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8387517
this place... ive never heard of, looks fantastic thank you!
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8392299
this i didnt think of, this may be great for the reset switch as a have a toddler who finds buttons very easily, more work for the button but also maybe much cooler to have to arm the reset switch
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8392319
27 minutes ago, jonnylaw13 said:
found these on the bay, could be a good choice though i think i would replace the switch
That would work but just make sure it's a momentary toggle type switch, something like this would work:
http://mnpctech.com/bulgin-modmytoys-computer-pc-power-reset-switch-mounting-plates-vandal-anti-resitant-lamptron/red-military-pilot-style-toggle-switch.html
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8392465
of all the places i looked mnpctech wasnt one, all i could remeber Bill having for switches are vandals. orded a on/off/on momentary from wish for $2 going to see how itll work with the arming cover
https://linustechtips.com/topic/652721-question-on-switches/#findComment-8392935
