Today i finally got money for 'new' cpu,so i decided to do on craigslist and find one.I found amd phenom x4 955 Black Edition 125 w.The problem is,on mobo cpu support list 955 that is 95 w is supported with f6 bios update.And the cpu i found is 125 w and its listed as N/A.Guys please help,i really need help!Will it work?
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=3262
http://www.cpu-world.com/CPUs/K10/AMD-Phenom II X4 955 Black Edition - HDZ955FBK4DGI (HDZ955FBGIBOX).html
http://www.gigabyte.com/products/product-page.aspx?pid=3262#ov
https://linustechtips.com/topic/652594-please-help/
damn thats one hell of an old board (AM2 , not even AM2+ or AM3 ), it will NOT support the 955be , try getting your hand on an decend board , i actually have an M4A97 DELUXE and a 940BE here that i recently retired
what is your current system made of?
Edit :  yea the board is actually AM3 but only a Low power board (95w tdp max) putting a 125 on there will end in smoke and tears
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/652594-please-help/#findComment-8381075
10 minutes ago, VerticalDiscussions said:
Why would you buy such an undermining and ancient cpu? So the motherboard doesnt support it, which means you should look for another one.
What if i told you that ancient cpu is 90 euros here(used !!!) ,anything new and desent is 150 euros+ and i would have to change mobo ram...everything pretty much
https://linustechtips.com/topic/652594-please-help/#findComment-8381159
if you are in germany , ebay kleinanzeigen , AM3+ board and FX6100 for 80€
PSU Tier list
https://linustechtips.com/topic/652594-please-help/#findComment-8381397
Just now, cojkeee_11 said:
Im from serbia.Ohh you germans...always getting the best prices... and wages :P
trust me , until recently Phenom 2 X4´s where in the 90´s here aswell , amd used market is NUTS , used intel tho ... xD thanks Tik tok and the floood of new cpus each other year  (haswell is cheap)
PSU Tier list
https://linustechtips.com/topic/652594-please-help/#findComment-8381438
