Hello !
I have an fx-8350 with an ARCTIC Freezer XTREME Rev. 2 (160 W !). My system is overheating very fast while rendering and gaming and shuts down because of the temperature protection. ( -> not playable) A system fan is mounted right behind it and two others are mounted in the front of the case (should be enough airflow). All fans are maxed out at 1000 rpm. I underclocked my cpu to 3.2 GHz and it's still overheating. I've no idea what's wrong, please help.
Idle: 55 °C / 131 °F
Some programs doing nothing (5% cpu usage): 76 °C / 169 °F
For those AMD haters:
On 20.1.2016 at 1:52 AM, Windspeed36 said:
No Trolling
  • This includes flame wars such as Microsoft vs Apple, NVIDIA vs AMD, Intel vs AMD
https://linustechtips.com/topic/652481-overheating/
If its that warm, then you likely have it mounted improperly. I would take it off, clean all the old thermal paste off and reapply it and re-seat it.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/652481-overheating/#findComment-8380278
