Streamreader help C#
By
Painey
in Programming
in Programming
Solved by Nuluvius,
You can avoid using the StreamReader entirely if you like:
var line = File.ReadLines("SomeFile.txt").Skip(1).Take(1).First();
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
play_circle_filled
Latest From ShortCircuit:
