Hi all I will try and keep it short,
I have a NetGear 104 with a sizable amount of films and series on. I supply myself and 5 other accounts on Plex for media. I'm after suggestions on something low power that will still run some transcoding of files. there's usually only 3 people using it at any one time. I've recently moved to a new house with terrible upload (welcome to the UK) and need to leave the NAS at my parents where upload is good so all can access it.
Do I need an old cheap 4 or 8 core xeon? Then what board. This will be running all the time so it needs to be low powered. I am open to buying second hand laptop from ebay, or building a machine but then I'm not sure what CPU would have the power and if a low power desktop PSU would still consume too much electric.
Cheers,
Nero
https://linustechtips.com/topic/651783-low-power-plex-pc-100/
What resolution will the server be transcoding at?
If you're talking about three 1080p transcoded streams you'll need something with a bit of power (a modern i3 for example).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/651783-low-power-plex-pc-100/#findComment-8373194
If you can get your hands on a semi-recent i3 or (preferably) i5 cheaply thats the way to go.
If jet engine sounds arent a problem you could probably try to get your hands on a second hand server on the cheap. (Something like a proliant G6 or up should do the thing.)
https://linustechtips.com/topic/651783-low-power-plex-pc-100/#findComment-8373236
I actually own at HP DL165 G7 with an 8-core Opteron which I don't use but was going to sell. It's a little on the loud side and I don't know what Watt it pulls from the wall.
https://linustechtips.com/topic/651783-low-power-plex-pc-100/#findComment-8373256
I scrapped a pile of G6's and two quad-cpu sparc servers at work today. We're not destroying them *yet* because the entire team secretly wants to give them to schools.
(Had to count 'stock' today as well, we have 100-something servers rusting away, G2 trough G6)
Company policy is to shred them, but it's expensive and wasteful, so we want to figure out a few contact points that want to do the paperwork for 'a slice of the pie' most preferably schools and/or non-profit organisations.
https://linustechtips.com/topic/651783-low-power-plex-pc-100/#findComment-8373304
Does anyone think http://www.ebuyer.com/722189-hpe-proliant-gen8-g1610t-819185-421-4gb-ram-microserver-819185-421 might be a nice solution to the problem, with the cashback its £125 or $170. Would that dual core do the job of some transcoding?
CPU is:
http://ark.intel.com/products/71074/Intel-Celeron-Processor-G1610T-2M-Cache-2_30-GHz
https://linustechtips.com/topic/651783-low-power-plex-pc-100/#findComment-8480293
Just use that man, it's probably around 100W which really anything is going to use that much power, assuming it can get the job done that is.
because for $100 I don't think you're going to be able to find a replacement performance wise
plus it's only going to use that power when it's actively transcoding
https://linustechtips.com/topic/651783-low-power-plex-pc-100/#findComment-8481737
