Usb Cable Powerer?
4 hours ago, ¨TrisT¨ said:Sorry for the extremely late reply, I was on holidays.
I'm confused, You said: "(...) leave the 2 data wires and ground wire connected. Then connect positive and ground to the USB charger.", so do I leave it connected or not?
I'm assuming it'd be like this(?):
Or perhaps like this(?):
Please tell me which one, or neither if that's the case, this is all quite expensive and I don't wanna mess anything up.
Maybe I'm missing something huge here, but wouldn't that make it so I couldn't connect the modem anywhere else?
I might end up doing that, but where I live people are fairly tech ignorant so you don't see those around. I was looking to build it, would spare me 10 bucks and a lot of the time waiting for it to arrive.
I didn't know if the data was being sent through USB, which is why I asked.
Connect the wires int this fassion:
The grounds need to be connected together to keep all the devices at the same electrical potential, however connecting all of the 5V supplies together could damage something. In this configuration the only thing that will get damaged is the $5 USB cables you will have to cut up to make the circuit. Finding a cable that can do this already would be ideal but if not you can simply cut up two USB cables and solder them together making sure you put heat shrink tubing on the exposed wires for safety reasons.
Edit: If the problem component is capable of getting power from any other source I would recommend either using that, or if you already are, beef it up more.
