Hi Guys
So i rma'd my today card Asus Strix GTX 970 fac oc Because my games / benchmarks crashes while playing it with wierd different screen colors
And browsing the internet/youtube also does the same problem. However problem does not occur if i use msi after burner fan speed up to 50-67% in the past months. But this day in the morning with high fan speed the probelm occurs continously so i rma it. Also the technician said i should have brought my whole pc so they can test it before sending to asus manufacturer, but he suspect my psu for not providing enough electricity. Why's that?
Some help pls.
Sorry 4 the long post, heres my potato spec: build on dec 23 2015
i7 4790k stock
H100i gtx
x2 kingston HyperX 8gb ddr3 1886
Crucial SSD 250gb
WB 1TB
Seasonic Xseries 650w plus gold
NZXT H440
Some attachmenta
20160724_191746.mp4
https://linustechtips.com/topic/650482-not-enough-electricity/
I suspect the GPU is causing artifacting so you made a good choice.
As for the technician and the power supply, don't worry about it because he doesn't know what he's talking about. Your build is getting nowhere near 650W (realistically around 350W under full load and everything overclocked). The power supply itself is great quality so I would rest easy about it.
Once you get the GPU back, see how it goes.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/650482-not-enough-electricity/#findComment-8359860
5 hours ago, LizarRea said:
Hi Guys
Some help pls.
i7 4790k stock
H100i gtx
Crucial SSD 250gb
WB 1TB
NZXT H440
Some attachmenta
20160724_191746.mp4
Your 650W Seasonic that can power 3 non overclocked 970s is not the problem.
https://linustechtips.com/topic/650482-not-enough-electricity/#findComment-8361287
