Hey LTT members,
a while back i finishd my customloop (for the build CLICK HERE )
and i was wondering if these temps are good for my setup.
my cpu idle 33/35C (4790k @4.6 1.28V)
my gpu idle 35C     (gtx 1070)
cpu under gaming load max 49C
gpu under gaming load max 42C
1x 280mm rad
1x 360mm rad
all fans running 1000rpm
i ask this because it is very hot over here at the moment around 30C
i asume the liquid temp will rise when ever the room temp goes up?
thx in advance
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/649275-temps-for-custom-loop/
Temps looks great.
Magical Pineapples
https://linustechtips.com/topic/649275-temps-for-custom-loop/#findComment-8349275
Those temps are fine, and yes your idle temps and max load temps will always be hotter when your tempratures in the room go up
CPU:R7 5800X    Motherboard: asrock x470 taichi ultimate   RAM: 32GB G.Skill Ripjaws-V 2X16GB    GPU: Gigabyte GTX1080TI gaming oc 11g   Case: Corsair 600Q Storage: 1TB Samsung 870(boot), samsung 850evo 500GB, 2TB Corsair MX500, samsung 2TB 970 evo plus, WD 5TB black    PSU: Corsair AX860    CPU cooling: Corsair H105
https://linustechtips.com/topic/649275-temps-for-custom-loop/#findComment-8349278
