so my brother has an ipad 2nd generation 16gb no lte
and we went camping
when we went camping there was too much rain and it went in my brother bags wetting everything and the ipad inside
so now there is an  water literally in the screen of the ipad
everything works perfet except for the fact that the water is very noticable
what should i do
i dont want to open it u myself as i fear damaging it
who should i go to
Mouse: Logitech g402 <3
Keyboard: Some Tenkeyless with blue kalih switches
Headphones: Logitech g430
Monitor: HP w2207h (1680 x 1050 @ 60hz)
PC Specs:CPU(AMD A8 6500 @3.5ghz), Mobo ( ASUS A68HM-E  FM2+), 1x1600mhz 4gb stick of ram, Random grey PSU, 920gb ssd
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
Laptop:Toshiba satelite with 8gb of ram a 480gb ssd and a mobile 2nd gen I3
https://linustechtips.com/topic/649030-help-with-ipad/
If you wana spend a couple bucks and do it yourself:
https://www.ifixit.com/Device/iPad
If not, anywhere that does screen replacement kind of stuff should be able to help you.
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8346969
3 minutes ago, dexxterlab97 said:
Go to a local fixing store. If your ipad still has warranty might contact them too
it doesnt have warranty got it as a gift from someone and they bought it from someonelse
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8346981
seal it up in a bag of dry white rice and let it sit for a week. Seriously, if you can see under under the screen, dont turn that shit on, theres a good chance theres water elsewhere that can short it out and kill it. Just turn it off, toss it in a bag of rice, zip that bag up and leave it alone for a week or two so the water can evaporate out.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8347011
In this case I think he should get actual Silica gel instead of Rice to absorb the humidity.
https://www.amazon.com/Hydrosorbent-900-Gram-Silica-Cubic/dp/B0028M7WK4
Mystery is the source of all true science.
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8347030
DO NOT TRY TO EVAPORATE THE WATER!
where is it gonna go? Likely onto the components
and we all know water+computer= no computer
So just leave it in rice or some other absorbent thing
Leave it for a day turned off then next day check on it.
Keep doing that until so don't see water. Once you don't
see water leave for another day before turning it back on.
Build Name:
Anton
CPU: I7 4790K
GPU: ZOTAC RTX 2060 SUPER AMP EXTREME
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
CASE: COOLER MASTER N300
PSU: THERMALTAKE 600 WATT
STORAGE: TOTAL 6.5TB, 512GB SAMSUNG 850 PRO BOOT DRIVE, 2TB HDD 1, 2TB HDD 2, 2TB WESTERN DIGITAL USB 3.0 BACKUP DRIVE
- CRACK!
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8347039
that can work, and probably far better, but the old rice bag trick is decades old, and countless techies can confirm it works just fine.
The silica will work better and faster, but yoy have to buy it, then wait dor it to get there. Rice, if you already have it is uber cheap and instantly ready :3
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8347321
did it though it wont go out of the screen
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8349139
guys i have lready tried this but it wont come out
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8349144
You seriously need to just let it be for multiple days, even weeks. It takes time, don't rush it.
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8352685
Well sorry man but it takes days and you can't just evaporate it... Metal iPad in a microwave it would overheat at best.... Orrrr blow up half your kitchen
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8352831
no seriously did it for a week
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8354592
Your op was posted two days ago, unless you started doing this over a week ago, or went back in time after thursday, you can see why I might not believe you.
Listen. If its out of warranty, and you don't want to pay a professional to fix it, then you seriously need to just zip it up in a bag filled with rice, or silica, and let it sit until the water inside has been absorbed out. Until you can no longer see any trace of water under the screen, do not power it on, and keep it zipped up.
If the water got in there, then the water will get out, it just takes time and you have to be patient.
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8357464
oh im fine with paying a professional
but the dudes at apple refused to fix it
and i posted this like 2 weeks after i put it in rice
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8357523
do you have any other reccomendations
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/649030-help-with-ipad/#findComment-8357528
