Hey guys I could really use your help.
I've never really used this forum before but I have been watching linus on yt for the past couple years.
I have a motherboard that I need a heatsink for. I really don't want any you should buy this or you shouldn't have gotten this or whatever, just need help.
It's an ASUS A68HM-E FM2+ AMD motherboard that I am trying to use and already have but my previous FM2 motherboard's heatsink won't work on it. I checked online and saw some heatsinks that were "compatible" according to PCPartPicker and the fact that they were the correct socket size heatsink but I need a heatsink that fits so I can use this motherboard over my old one. I also have a Gigabyte AMD Radeon R9 270 Windforce that is sitting in the PCIe slot in case you guys are thinking about clearance or whatever.
If need be I can send you guys a pic of the motherboard incase you need a more in-depth picture of it. but thanks guys all help is really appreciated.
(LINK TO MOTHERBOARD)
Click here. or http://www.newegg.com/Product/Product.aspx?Item=N82E16813132407
https://linustechtips.com/topic/648508-need-help-with-heatsink/
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8341179
2 hours ago, Energycore said:
Yeah I can afford these. But you're sure they'll fit coz the first one has like plastic push in plugs for the screws. The heatsink looked kind of long.
Thanks,
zurare
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8341711
Just now, zurare said:
Yeah I can afford these. But you're sure they'll fit? The heatsink looked kind of long.
Thanks,
zurare
They will fit into the socket. As for whether they'll fit the rest of the motherboard, the best way to find out is by looking at pictures of them.
https://www.techpowerup.com/reviews/CRYORIG/H7_Universal/5.html
As you can see, it's very thin toward the bottom, then stretches out in a big stack that should be able to go over other components of your motherboard.  Make sure your case is wide enough to fit it.
Computer Specs:
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8341717
Yeah I got an ATX Mid-Tower (corsair carbide 200r) so it should be able to fit it. Alright thanks man I'll see to ordering it soon :)
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8341728
Yes it'll fit the 200R
Computer Specs:
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8341731
Hey um sorry to keep bothering you, but what about the first one you used? I see it's a bit cheaper.
 http://pcpartpicker.com/product/FNXfrH/cooler-master-cpu-cooler-rrht228pkr1
How would using it work? I'd be able to use the plastic plugs where the metal screws on the motherboard are, right? And I'd just screw into the spreader thingy that has the plastic plugs? Or what about the "clip mounter" thing that they say is an alternative way of mounting it? Would that work for my motherboard?
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8341778
It's smaller and you should have a different mounting mechanism for AMD sockets.
But I recommend the H7, the other one was just in case you couldn't afford the H7
Computer Specs:
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8341846
Did you try it already and see that your heatsink didn't fit? The mounting should be the same for both boards.
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8353585
Sorry, been a little busy preparing to go back to school and such. It makes me want to die inside. Lol.
I went with the Deepcool Gammax 400 which is a big ass heatsink and due to airflow optimization and some nice fans my computer constantly blows out cool air with the components staying at a very low temperature. It didn't break the bank and works great but for a MicroATX board and may be for a MicroATX case, you probably will have clearance issues. Also the AMD "clip" thingy which I didn't have on my previous board is a pain in the ass and I was honestly concerned of crushing the CPU when trying to put it on. However it works great and it will fit a 6600K which I plan on picking up next year with a Hydro GTX 1080. I'm pretty sure that's what I'll end up buying as I'm not really a hardcore gamer but a poweruser who loves his FPS count xD. Anyway I'm going to stop my rambling and say thanks to the tremendous and very fast replies of both @WoodenMarker and @Energycore. I've never really been big into forums but I think that's now changed as my PC is more capable and I'll be getting more into PC gaming and back into Video/Image Editing/Creation. Again, thank you very much :)
-zurare
https://linustechtips.com/topic/648508-need-help-with-heatsink/#findComment-8394574
