Hi guys, i need some advice to choose the PSU for my new rig.
Here's the config:
Case: NZXT Phantom 630
Cpu: Intel i7-4930k
Mobo: Asus X79-Deluxe
Cpu Cooler: Noctua NH-U12S
Ram: Kingston HyperX Genesis 1600Mhz CL9 - 32GB
SSD: Samsung 840 Pro - 256GB
HDD: WD Red Caviar - 4 TB
VGA: Asus GTX780 - DC2OC - 3GD5
Optical Drive: Pioneer BDR-208DBK
I think that the Corsair AX860 is enough for this configuration. What do u think, guys?
Thanks! :D
https://linustechtips.com/topic/64766-psu-advice/
It's more than enough, I run the rig in my sig off a 750w psu but why so much RAM?
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/64766-psu-advice/#findComment-885822
This^. Ram disk maybe? Only thing I can think of.
Intel 3570k @ 4.4 GHz |Asus Sabertooth Z77 |EVGA GTX 660 Ti FTW |Kingston HyperX Beast 16 Gb DDR3 1866 (2x8Gb)
|Samsung 840 250 GB |Western Digital Green 2TB 2x |Cooler Master 850w 80+ Gold |Custom Water Cooling Loop |Noctua NF-F12 4x
|Noctua NF-A14 3x |Corsair Carbide 500R (White) |Corsair K95 |Razer Mamba |Razer Megalodon |Samsung SyncMaster T220 2x Computer Bucket List   Greatest Thread Ever   WAN Show Drinking Game  GPU Buyers Guide
https://linustechtips.com/topic/64766-psu-advice/#findComment-885828
must be, otherwise it's obscene overkill.
https://linustechtips.com/topic/64766-psu-advice/#findComment-885829
I would assume looking at the CPU/GPU that the OP is doing a lot of editing (Photoshop maybe). Though one would usually see a scratch disk...
https://linustechtips.com/topic/64766-psu-advice/#findComment-885837
Thanks for the replies :D
I need so much ram because i use it for editing (Photoshop, Illustrator, Maya).
That makes sense, you might want to add a scratch disk to the build so you don't mess up your storage/boot drives with all the writes. As for PSU options go for Gold rated (highly efficient) from Seasonic or Corsair (Seasonic, actually manufactures most PSU for many companies) I would expect 750w would be enough, though the one in your list is fine for wattage if a little overkill.
https://linustechtips.com/topic/64766-psu-advice/#findComment-885868
^I agree with the things said in this post.
https://linustechtips.com/topic/64766-psu-advice/#findComment-885895
