I need a low profile usb 3.0 hub. I just need 4 ports and aesthetics are not as big of a concern. The usb (male) connector needs to be really small( yes I know that the part that goes inside of the female usb port is the same size I am talking about the rest of it that sticks out), and the rest of the hub doesn't need to be really small. Thinking of spending no more than $20. Or, if there is a right angle low profile usb adapter, or a low profile usb extension that could work too. I have 2.5 cm of clearance on the usb port. And this is for a laptop.
Edited by Hulkbert
https://linustechtips.com/topic/647395-low-profile-usb-hub/
If you have a 5.25" drive bay you can get a USB hub
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/647395-low-profile-usb-hub/#findComment-8329557
18 minutes ago, westonb27 said:
Do you think there is anything smaller?
https://linustechtips.com/topic/647395-low-profile-usb-hub/#findComment-8329736
I looked around a little and i personally haven't seen much else. Similar sizes sure, but not smaller than that. If you want right angle youre probably only gonna find single usb ports (acting as an extension) rather than a hub.
https://linustechtips.com/topic/647395-low-profile-usb-hub/#findComment-8330392
Any good right angle connectors?
https://linustechtips.com/topic/647395-low-profile-usb-hub/#findComment-8335682
