So i need a power block (one of these things)
https://www.amazon.co.uk/Belkin-E--Plug-SurgeStrip-White/dp/B0002AG0F2/ref=sr_1_7?ie=UTF8&qid=1471895037&sr=8-7&keywords=belkin+surge+protector
for my PC but as i was going to buy it i noticed it said
  • Features a 238 J energy rating
Now i don't know what that means in Watts but i assume J is the same as W (physicists please correct me if im wrong) so my question is if i have a 550W PSU will this power block manage to draw that amount of power safely?
https://linustechtips.com/topic/647335-power-block-help/
As W (Watt) is J/s (Energy(=Joule) per second) a 550W PSU will draw 550 J/s when under max load, so my guess is no.
[Edit] After some googling around, it probably refers to the surge protection. The rating then means that if you have a surge of up to 238 J it will protect your device(s). Normal operation with that PSU should probably be fine. Someone please correct me if I'm wrong though :D
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/647335-power-block-help/#findComment-8329013
4 hours ago, Majestic_Koala said:
-SNIP-
As mentioned that would be the surge rating, you want a high rating so it can absorb power surges to protect your equipment from sudden large flucations in power, that unit while it would work is fairly basic something a little more substantial:
https://www.amazon.co.uk/APC-PMH63VT-UK-SurgeArrest-Office-Protector/dp/B01566M0HI/ref=sr_1_12?ie=UTF8&qid=1471910123&sr=8-12
https://linustechtips.com/topic/647335-power-block-help/#findComment-8329901
