Canned Air Question
Go to solution Solved by mgsstar,
Can I clean GPU PCB with the spray?
Yes you can do that I did this on my gpu and didn't have problems with it.
i know the whole rumors and such, here are the question,
I am pretty similar with this, just wanted to confirm...
-You can spray it on things such as Motherboard Circuits "gently" as well right? GPU PCB etc...
-It is also referd to as Gas Duster and other names like that...
->http://www.amazon.com/Compressed-Gas-Duster-10oz-Pack/dp/B004E2MF5S/ref=sr_1_1?s=electronics&ie=UTF8&qid=1381550320&sr=1-1&keywords=canned+air+for+computers
To love is to risk not being loved in return. To hope is to risk pain. To try is to risk failure, but risk must be taken because the greatest hazard in life is to risk nothing.
https://linustechtips.com/topic/64726-canned-air-question/
:ph34r: just act cool
I am defiantly sure of this, just a confirmation...
https://linustechtips.com/topic/64726-canned-air-question/#findComment-885272
Why not? That's what it's for, getting rid of dust. Just point the thing at the thing and press the thing and poof!
https://linustechtips.com/topic/64726-canned-air-question/#findComment-885279
A leaf blower is fine too
Thats taken by Carey Holzman
https://linustechtips.com/topic/64726-canned-air-question/#findComment-885311
Never invert the can though.
1. that rabbit looks sad
2. Staff, you are staff...
https://linustechtips.com/topic/64726-canned-air-question/#findComment-885312
I assure you my intentions were different. I did not know who he was until googling that, but our technology has advanced rapidly and they're quite compact and easy to use these days. Might still disturb the neighbors though.
Be sure to watch your fingers.
Figuratively of course, because then you might break something moving this death machine around in there if you're not looking at what you're doing.
Error: 410
https://linustechtips.com/topic/64726-canned-air-question/#findComment-885345
your comments have forced me to question your sobriety ATM.... ;)
like waht^^
yes....he is staff....???????
wat. who.
depending on what youre cleaning you could just wipe over with a VERY LIGHTLY damped paper towel with alcohol.
such as your GPU backplate. or the top side of a HDD or an SSD.
depends
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/64726-canned-air-question/#findComment-885357
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/64726-canned-air-question/#findComment-887923
