Hey, I don't really know how to go upon this I just looked around and saw nobody covered this across the interwebs.
Anyways, just earlier I updated my graphics driver, it screwed up the saturation and well... everything about my display settings. When I go into NVIDIA CONTROL PANEL to try and fix the issue it doesn't work. I slide the slider across the Hue and everything and it just doesn't change anything. Also keep in mind my PC is ancient, Nvidia Quadro 4000 graphics card, and ideas on how I can revert the driver update or fix my color issue??? I really need help on this one.
https://linustechtips.com/topic/647000-nvidia-control-panel/
Use DDU (Display driver uninstaller) to wipe the old graphics driver then download the newest from nvidias website that works with your Graphics card and operating system
https://linustechtips.com/topic/647000-nvidia-control-panel/#findComment-8331644
