1 minute ago, thou mighty one said:
so i watched one of the as fast as possible and i bought a tpm now i ran everything and it seems fine yet i cant find any videos on how to install it just to make sure i did everything properly any tips as to what to look for just to double check myself ?
From what I know you plug it in, make sure you enable it UEFI, and there may be something in Windows you have to do.
All I know is when it's enabled, you should see a new option in the right click menu on Windows.
https://linustechtips.com/topic/646990-tpm-module/#findComment-8325364
