I just overclocked my 6700k to 4.6ghz at 1.4v and an ambient temp of 23 degrees celsius with the h100i GTX and I stress tested it on aida 64 for about 30 minutes and the max temp it reached was 67 degreses celsius. Is this a safe OC for everday use and is it stable?
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/646958-overclocking-help/
Yep, the 24/7 recommended voltage is 1.4v or lower. Those temps are gorgeous. Good OC.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8324956
Thats good to hear I definetly want to try other apps like cinebench and prime 95 before I continue.
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8324968
I wouldn't bother with Cinebench, it's a benchmark rather than a stress test. Either do longer Aida passes (30min is nothing, really) or skip straight to P95.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8324987
Ok and how long should I let it run for? And did I win the "silicon lottery"
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8325026
If you'd like to push your OC harder, monitor it for an hour or so before trying to increase the frequencies / decreasing voltages. If you are happy with your current level, though, give it at least an overnight 8h pass while you sleep.
As for winning it, I'll refrain from making any comments until you've verified your stability on a lengthier test.
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8325043
Wow! 8 hours!? Are you sure that's healthy?
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8325049
I don't understand. I recall a video Linus is saying how Prime95 is a dangerous stress test, and might break your system, but everyone here still uses it, I do too, and it works perfectly. Was Linus wrong?
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8325052
I wouldn't use prime95
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8325062
Went to 29 days running straight before I had to shut it down. It won't hurt your hardware at all, don't worry about it.
Not to say that he is wrong (even though that's the case), but don't watch his videos to learn about stuff, watch it for the entertainment.
Prime95 isn't dangerous if you are OCing things properly, which you should. Think of it as car: drive it without ever having a lesson and you are sure to murder people; have a few classes, though, and you'll be fine. Likewise, spend a Sunday afternoon reading about how to OC and you'll be 100% safe to use P95.
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8325163
wow thats a lot. Ok then I will run aida 64 tommorow night and I will stress cpu, fpu, and cache, and should I stress anything else?
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/646958-overclocking-help/#findComment-8325257
