1 minute ago, Beeeyeee said:
Hey guys! Using these parts help me find the best PC I can get for $900!
:D
http://pcpartpicker.com/list/Z8mbhq
peripherals os monitor or anything else included?
Mouse: Logitech g402 <3
Keyboard: Some Tenkeyless with blue kalih switches
Headphones: Logitech g430
Monitor: HP w2207h (1680 x 1050 @ 60hz)
PC Specs:CPU(AMD A8 6500 @3.5ghz), Mobo ( ASUS A68HM-E  FM2+), 1x1600mhz 4gb stick of ram, Random grey PSU, 920gb ssd
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
Laptop:Toshiba satelite with 8gb of ram a 480gb ssd and a mobile 2nd gen I3
https://linustechtips.com/topic/646716-best-900-build/#findComment-8321850
also what are you planning to do with it
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/646716-best-900-build/#findComment-8321854
PCPartPicker part list
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ Newegg)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  ($20.00)
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard  ($109.67 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Video Card: EVGA GeForce GTX 1060 6GB GAMING Video Card  ($249.99 @ SuperBiiz)
^Out of stock atm though
^You can go for the $269 Gigabyte 1060 if you stick with just 8gb ram
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($82.98 @ Newegg)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($71.13 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($35.00)
Total: $918.74 - Accurate price is $889.93 since shipping costs are free.
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/646716-best-900-build/#findComment-8322221
Hey thanks man!:)
https://linustechtips.com/topic/646716-best-900-build/#findComment-8322234
Surprisingly similar to antisleep's suggestion :P
PCPartPicker part list: http://pcpartpicker.com/list/4hwxcc
Motherboard: ASRock Z170 Pro4 ATX LGA1151 Motherboard  ($92.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($64.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1060 6GB WINDFORCE OC 6G Video Card  ($269.95 @ B&H)
Power Supply: Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($75.98 @ Newegg)
Total: $906.87
Generated by PCPartPicker 2016-08-21 12:06 EDT-0400
Folding@Home ~75k points per day | My Simple Air-cooled Machine Maintenance Guide | Dutch Talk | Building a Wooden Popsicle Stick House
Main rig: i7-3770 stock - ASUS P8Z77-M - 8GB DDR3 1600MHz - 2x Radeon HD6970 2GB - SilverStone GD05-B - Corsair RM650x
https://linustechtips.com/topic/646716-best-900-build/#findComment-8322269
curious as to why you keep recommending this psu... it's not the best and it costs as much($79 w/o rebate) as tier 1 psu's like evga G2/GS
there are even higher tier psu's, not necessarily gold rated, that are cheaper
https://linustechtips.com/topic/646716-best-900-build/#findComment-8322693
