Would like some advice to maybe make my build better in both value and performance. Feel free to change the build but I probably won't be able to go any higher in price.
CPU: Intel Core i5-6600K
Motherboard: Asus Z170-E
Video Card: Strix GTX1060 OC 6GB
SSD: Kingston UV400 120GB
Power Supply: EVGA 600B 600W Bronze
Hard Drive: Seagate 2TB SATA III
Case: Corsair Carbid Series Spec-2 Mid Tower
Country: Canada
Budget: Under 1.2k CAD or Under the parts listed above
https://linustechtips.com/topic/646644-help-making-my-build-better/
budget? which country do you live in?
2 minutes ago, Redzeric said:
Sorry I just added it
do you already have a cpu cooler and ram? are you gonna OC?
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($299.98 @ DirectCanada) if you're gonna play games at 1080p 144z, get an i7/xeon as this will bottleneck.
Motherboard: ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard  ($99.98 @ NCIX)
Memory: G.Skill Ripjaws V Series 8GB (1 x 8GB) DDR4-2800 Memory  ($44.99 @ Newegg Canada)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($74.98 @ DirectCanada)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($57.99 @ NCIX)
Video Card: Gigabyte GeForce GTX 1070 8GB Mini ITX OC Video Card  ($529.00 @ Vuugo) wait for stock to arrive.
Case: Deepcool TESSERACT SW RED ATX Mid Tower Case  ($39.99 @ Newegg Canada) great case for the money, i have it and its great.
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.98 @ NCIX) much better than the 500b.
Total: $1201.89
Generated by PCPartPicker 2016-08-21 07:37 EDT-0400
I've never in my whole life heard a i5 is gonna bottleneck if you're wanting to play at 100+fps at 1080p...
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
Country: Canada
Total: $1201.89
I'd go for this ^^^ it's a good build! :)
most people are saying an i5 is gonna bottleneck a 1070 or a 1080.... and it's complete bullshit and I'm tired of it.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Well if it was a locked sandy or older i5 then yea, it probably will bottleneck a bit but I don't think anyone is building a computer with pre-sandy hardware here...
Total: $1201.89
If possible can you get me a build with maybe 1k CAD just in case I can't build this one. Thanks you!
Video Card: Zotac GeForce GTX 1060 6GB Mini Video Card  ($330.24 @ shopRBC)
Total: $1003.13
Generated by PCPartPicker 2016-08-21 08:07 EDT-0400
