Help with drain port config
10 minutes ago, yazerak said:This was my first custom loop and i just thought about how the hell im going to drain the thing when the time comes so i know im stupid for overlooking this but I'm curious as to the best suggestion and set up of a drain valve/ plug in my loop.
I have a xspc ion pump/res combo with g1/4 chrome compression fittings and 7/16 (11.1mm) ID 5/8 (15.9mm) OD tubing
And a copper rad and cpu block
So where would be the best spot to set up this drain and what parts would you suggest for such
Since your using flexible tubing it's not too hard you can take off the CPU block and undo one of the fittings outside of the case to drain the fluid. As mentioned putting it on the res would be a good location for the drain as it holds the main volume and in this case one of the lowest points.
