4 minutes ago, MagnusGrønstad said:
oh yes
Maximum Compatibility:
  • VGA Card length: 423mm
  • CPU cooler height: 170mm
  • PSU length: 200mm
423mm is a hella long card
thank you for the help but also im using  MSI Z170A MPOWER GAMING TITANIUM ATX LGA1151 Motherboard  as my motherboard and I was woundering If I would have enough ram clearance to have a push pull config on the rad for the cpu same case
https://linustechtips.com/topic/645896-case-question/#findComment-8313242
that depends on the height of yer ram and where ya want to put that config. also how big the radiator and fans are.
https://linustechtips.com/topic/645896-case-question/#findComment-8313259
ok also the case shows that it will accept a gpu length of 320 but when I check the zotac amp extreme 1080 it says length is
325mm x 148mm
https://linustechtips.com/topic/645896-case-question/#findComment-8313273
not for me Im looking on the website rn
I'll be damned. gotta inform my retailer they've listed the wring specs!
well, in that case the GPU ya want won't fit. pick a shorter one
                   (^ See what I did there? (͡ ͡° ͜ つ ͡͡°) )
https://linustechtips.com/topic/645896-case-question/#findComment-8313310
lel
https://linustechtips.com/topic/645896-case-question/#findComment-8313317
