Hey guys,
decided to reinstall tf2 yesterday and i have nothing but fps problems on new machine.
For the first 10 minutes the fps sits around 280fps and is fine but then after that it drops to 180 then down to 100.
Cpu temp is only 60 degrees C and Gpu temp is only 65-70...
I've been changing gfx settings left right and centre but to no avail.
Pc specs are in sig
Ryzen 9 7900X
Asrock X670E PG Lightning
32GB G.Skill 6000mhz DDR5
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/645692-tf2-fps-issues/
10 minutes ago, MrBaker89 said:
Hey guys,
Pc specs are in sig
Are you doing anything in the background?
Check the power settings with MSI afterburner.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8310853
nope nothing running in the background...
Power settings to gpu are all okay.
Ryzen 9 7900X
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8310858
Check with MSI afterburner, look at the graphs and see if the power or clockspeeds drop off at the times when you get FPS problems.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8310861
Tried that :(
No significant movement in clockspeed or power when fps drops...
Could it be the cpu? surely 60degrees for a 6600K isn't a problem?
Ryzen 9 7900X
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8310869
1 minute ago, MrBaker89 said:
Tried that :(
So all of the numbers are during gameplay? (And that CPU temp is fine) Check CPU and GPU usage.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8310878
9 minutes ago, manikyath said:
Could you do a cpu and gpu benchmark to check "worst case scenario" temps?
(For the gpu preferably a benchmark that pulls higher fps numbers, like tf2 should.
I've ran the Heaven Unigine benchmark and gpu temp hits 71 degrees and Cpu hits 63degrees highest after running for quite a while.
Ryzen 9 7900X
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8310913
Nothing out of the ordinary for Cpu or Gpu usage.
Ryzen 9 7900X
1TB Samsung 990 Pro
Rdna 2 iGPU
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8310916
Numbers?
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8310919
You see, Team Fortress 2 doesn't have something called proper optimization. As in I've gotten an i7-2600 to drop to 29FPS on Suijin.
https://linustechtips.com/topic/645692-tf2-fps-issues/#findComment-8313978
