Hey I record with a Blue Yeti using XSplit. For some reason I've noticed he audio does this weird popping. It sounds almost like peaking but it's definitely not. The mic is on the lowest gain setting and not right next to my mouth. It's only hitting -1Db on the peaks.
Maybe it's a setting I have on? What's the best settings? What can I do to fix it?
example:
https://linustechtips.com/topic/645656-audio-popping/
Do you have a Nvidia card, especially a Pascal one?
        Pixelbook Go i5 Pixel 4 XL
https://linustechtips.com/topic/645656-audio-popping/#findComment-8317235
5 hours ago, Beeeyeee said:
Yeah I have a 1080
This is a known issue with Nvidia cards, Pascal in particular. You can update to the latest drivers, disable turbo core and close back round programs. Other than that you have to wait for Nvidia to fix it.
https://linustechtips.com/topic/645656-audio-popping/#findComment-8323488
