Help me overclock please
Go to solution Solved by Bananasplit_00,
Just now, GreezyJeezy said:
and check temps
yah forgot to mention that, make sure it dosent go above 85 or so C
you go into the BIOS and find the CPU multiplier and put it up a little bit, like 5 or so to begin with and then start the computer and run a stress test like AIDA 64 for 10min, if it crashes then go back into the BIOS and raise the voltage a little bit and keep doing that, just remember to not go above 1.4V and preferably not over 1.35V
Builds:
https://linustechtips.com/topic/645492-help-me-overclock-please/#findComment-8309004
and check temps
https://linustechtips.com/topic/645492-help-me-overclock-please/#findComment-8309010
and check temps
Builds:
https://linustechtips.com/topic/645492-help-me-overclock-please/#findComment-8309015
