I got a new computer, so I copied all files I need from my Laptop to the new computer. After that I wanted to restore the laptop so it would be like new without any of my stuff on it. I started a system restore, and when it started restoring, I decided that it's probably better if I delete the files myself. I stopped the restore, but now Windows doesn't work it says that I have to insert the Windows disk which I don't have. What do I do??
It had a Windows 7
https://linustechtips.com/topic/645441-messed-up-with-system-restore/
Why dont you just reinstall windows via installation media?
I would indeed recommend you either make a Windows 7 install USB to reinstall Windows or to use the provided installation media that came with the laptop. Assuming it came with installation media, which reading over OPs first post again, he doesn't have.
You can get a Windows 7 ISO here: https://www.microsoft.com/en-US/software-download/windows7
My rigs:
NEW Ryzinator build:
CPU: AMD - Ryzen 9 3950X 8-Core Processor
Motherboard: Asus - PRIME X370-PRO ATX AM4
RAM: Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-2666 @ DDR4-3066
Storage: (3x) Samsung - 850 EVO-Series 500GB 2.5", Samsung - 960 EVO 250GB M.2-2280
PSU: Seasonic Prime TX-750
OS: Microsoft - Windows 10 Pro 64-bit
Additional fan: Noctua - NF-A14 PWM 82.5 CFM 140mm Fan
Case: Fractal Design - Define R5 (Black) ATX Mid Tower Case
GPU: ASUS Radeon RX 580 Dual OC 4GB
Display: MSI 27L Optix MAG272QP @ 165Hz
OLD Build (SOLD):
CPU: AMD FX-6100 Motherboard: ASRock 960GM/U3S3 FX (VRM overheating, don't buy) RAM: 8GB Kingston ValueRAM GPU: Onboard ATI Radeon 3000 Graphics Case: Corsair Obsidian 500D Storage: Hitachi HDS721010CLA332 1TB, 119GB SAMSUNG MMCRE28G5MXP-0VBH1 (SSD), 465GB Western Digital WDC WD5000AZRX-00L4HB0 (SATA)  PSU: Be quiet! - Straight Power 10 400 Watt Cooling: Cooler Master Hyper 212 EVO OS: Windows 10 Pro x64
Retro gaming build:
CPU: Intel Pentium 3 Coppermine @ 800MHz Motherboard: Asus P2B i440BX BIOS 1012 FSB: 133 MHz RAM: 1x 128MB Hynix PC133 SDR SDRAM GPU: ATi Radeon 9200 256MB AGP Case: Full Tower case (unbranded) Storage: CompactFlash card to IDE converter (16GB card) Sound Card: Aztech 2320 ISA Cooling: Stock heatsink fan OS: Windows 98 Second Edition
I got Windows7 ISO, I put it on the USB, but this happens:
D
What did you use to put it on a USB? I'd reccomend Rufus or http://wudt.codeplex.com/ . You can't just unpack the ISO afaik.
My rigs:
OLD Build (SOLD):
Retro gaming build:
1 hour ago, MSWindowsinside said:
D
I've tried to copy and paste the files and I've tried different programs, but nothing worked. I tried Rufus and the only thing that changed was that it now says "Press any key to boot from USB", but that's it. The Windows USB/DVD Download tool says that there's something wrong with the ISO or the USB.
17 hours ago, scritous said:
Download Rufus. https://rufus.akeo.ie/
Download MiniTool Partition Wizard Bootable 9.1 https://www.partitionwizard.com/partition-wizard-bootable-cd.html
Burn it with Rufus and Boot from USB. Remove System Reserved + Local Disk C:
Now burn your Windows ISO and boot. If it doesnt, try to burn one of any linux distros and notice if it works.
Edit: As far as I understand you want to delete your files. Just remove all of HDD on Partition Wizard. Also probably you damaged boot manager when restoring system.
I'm currently in the MiniTool Partition Wizard and I'm unsure what to do. As of right now I don't really care about deleting the files, I just want the laptop to work.
It's weird. Delete all partitions but dont create a new one this time. If it doesnt work too, burn ubuntu to USB and boot it. Lets see if it makes any difference.
I deleted all partitions and didn't create one, but that did not help. I was able to install Ubuntu.
Just now, scritous said:
Interesting situtation. I think you have to try another Windows ISO.
Where do I get them? I can't get them from Microsoft because when I enter the Product key it says that I need to contact the manufacturer because Windows was already installed on the laptop. I went on Toshiba's website, but wasn't able to get the ISO.
On 8/21/2016 at 10:19 PM, scritous said:
I dont think it's accepted on this forums but you can get it from illegal sites also you can find Windows 10 here legally.
https://www.microsoft.com/en-us/software-download/windows10/
I found out what the problem was. It wasn't the ISO's, it was the USB I was using!
