I reinstalled windows then my i realized my wireless adapter wont work anymore because it doesnt have the drivers and i cant find the driver disk. So I tried LAN, it didnt work. No lights on the port and the lan conected light on the router is not on. I tried installing the lan driver from gigabyte's site but it say it cant find the "network adaptor". Wi-Fi on other devices work fine. I dont have anothor device to test the lan with though.
Motherboard is gigabyte GA-Z77X-D3H
"Soundcards will give you more FPS."
https://linustechtips.com/topic/645205-lan-not-working/
Doublecheck that in your BIOS you have the LAN enabled.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305744
If you go into your device manager, under network adapters, do you have anything with a yellow triangle?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305767
Go to your device manager, Look for your lan, Uninstall it/delete it.... Reboot system, See if it installs as you have uninstalled it / deleted it... That it will hopefully install. If that does not work. Go back to device manager and click on update software drivers via the internet method.
A menace to the scammer world. They hate me wasting their time when they are conning the innocent and giving to the idiots.
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305796
There is no network adapter in devicd mananger.
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305816
Sounds like defective. I would recommend using a 2nd computer to download the drivers for your wireless card if you can and then transfer then via USB.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305829
Its totally up to you if you want to do this. I would suggest do a fresh install of windows 7 again and I shall explain why.
when I installed windows 7, I had network issues, It would either knock out my lan or It would not allow me to initalize a connection so even tho I had internet, My IE or Chrome would not show there was an connection.
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305840
Also before i reinstalled it work fine
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305846
1 minute ago, feehi said:
It REALLY old so i cant find it.
you're not looking hard enough. Whats the make/model of it?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305847
I dont have the cd or iso, my dad took it to the repair shop.
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305850
You can download the ISO then use RUFUS to get it onto a USB thumbdrive / memory stick etc then install it from there as long as you have your windows key.
https://linustechtips.com/topic/645205-lan-not-working/#findComment-8305858
