currently my sound setup looks like this
room >- "hollywood 3-way" 50w speakers and an old crappy stereo system, i´ll check the name later
pc -> sennheiser game one (mic starts failing again, i´ll try RMA again or ask for a refund and get something that doesnt die every 5-6 months)
my budget for headset+mic is ~300 bucks
and ~250 for the "sound system"
as replacement i was thinking about something like the "harman kardon" (maybe with bluetooth)       i saw that @ShadowCaptain uses them, so they seem to be worthy
and some new headphones + mic
maybe a blue yeti "snowball" mic + sennheiser urbanite or beyerdynamics
would you recommend using wireless headphones?
glad about advice and suggestions
thanks in advance
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/645195-budget-audio-solution/
5 minutes ago, Bl00dgod said:
SNIP
Get the MMX300s if you want a headset! one of the best mics on a headset and its got fantastic sound for games and music (its basically some DT770s with a crazy good mic on it)
Or get some nice Sennhesiers/Beyers and mod mic (or an AT2020 if you want something like that)
I really do like my Harmon Kardon system, mostly because it looks awesome and was designed by Jony Ive - it sounds great for the money though, I just have the basic one, bluetooth was useless to me as my pc set up as I can control my music from my phone via spotify
but tons of options for speakers depending on what you want!
https://linustechtips.com/topic/645195-budget-audio-solution/#findComment-8305572
1 hour ago, ShadowCaptain said:
snip
i´d control the harmon kardon from pc too
i guess anything has a better quality than the current speakers... and stereo is ok
loved the ad of the SH urbanite .. dont know what their marketing did there but its unique ... must been stoned
when i had to choose last time i went the sennheiser way but beyerdynamics will be the way this time i guess
the mmx is great, like your review on yt @ShadowCaptain
both will be used on my asus z97 ar onboard sound
do i need a Y adapter/hub to connect headset and speakers at the same time? changing the plugs always was a pain
always used my vnc playlist but spotify seems worth a try too and being able to control it on my OP2
https://linustechtips.com/topic/645195-budget-audio-solution/#findComment-8305641
