So in my room I only have one Ethernet wall jack. form the wall I run it to a Switch then from there one cable goes around my room to my PC and another runs the other way to my TV cabinet and goes into my Xbox one. Now I moved my Xbox 360 to my room. Is it possible to use another network switch to spit the cable going to the xbox one so i have two one for both Xboxs? so basically can i split and already split cable without slowing down speeds?
Thanks!
https://linustechtips.com/topic/644856-ethernet-cable-split-question/
You can connect from a switch to a switch (to a switch and further), but you might not get maximum speeds out of it.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
well you'll only be using one at a time, and i doubt you'd saturate the connection.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Thanks!
Why wouldn't you just run a second cable from the current already in-place switch, bundled w/ the one heading to the TV Cabinet? Then you'll have two cables that you can use, one for the XBO and one for the XB360.
But to answer your question - You can daisy chain switches multiple times with minimal performance loss, as long as your overall network isn't being hammered too hard.
All that it will mean is that your traffic will get aggregated at the switch and limited to the uplink cable's speed (Eg: Two devices, both Gigabit capable, connect to a switch, that connects to your main switch. Both devices individually have a combined bandwidth of 2Gbps, but are limited to a total of 1Gbps due to sharing a single port going back to your other switch). Since most internet connections are significantly slower than 1Gbps, you likely won't have any performance issues with this setup.
Though I would still advise simply running a second cable down to the TV cabinet.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
