New PWM fans
GermanPCBuilder
Hey I need 5 new fans for my new case 4 of them should be 120mm and the fifth should be a 140mm as the title says they must be pwm fans and they shouldn't be too expensive but also not too loud fell free to suggest some :)
Fratal Design's Venturi fans are pretty good while not being overly expensive for the most part.
Noctua redux are good if you care about noise. They're cheaper that the normal noctua fans, and have a better colour scheme. Bitfenix fans also are quiet, while still shifting a lot of air. Both are good prices.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
So the Bitfenix Spectre Pro white PWM fans are good? They fit in really well with my color scheme
The non pro versions are excellent, and cheap. I'm assuming the Pro ones will be better.
Main Gaming Rig:
Secondary PC:
Pro is just a way for them to bump up the price.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
What are you specs and where in the case do you plan to use them?
My Specks Are : i5 6600k ( be quiet shadow rock slim cooler ) and a GTX 1060 from ASUS ( dual 6Gb version) the 4 120mm fans are going in the top and the 140mm one is going in the back of my case ( it's a core V21 by ThermalTake )
Silent 12's and PW2's are good.
http://de.pcpartpicker.com/product/ZpCwrH/gelid-solutions-case-fan-fnsx1210
http://de.pcpartpicker.com/product/4GsKHx/be-quiet-case-fan-bl047
The ones on the top are on a radiator?
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
Nop just for normal air flow
Whats your fan setup? the 140mm is at the back as exhaust and you have 4 on top as intake?
4 hours ago, WoodenMarker said:
You got that right , and I also have a 200 mm fan in the front as an exhaust
and the ones at the top are on a radiator or its pure intake? Also whats your limit on noise level? Under 30 dBA?
It's just a pure intake I have no rads in my build at all.
My limit in noise level? .... I don't know ,the quieter the better
Whats your color theme, so I know which ones not to recommend
A lot of black with white accents ( RAM and graphics card )
And also I figured that the Bitfenix Spectre PWM are good looking and they have good specs ( I think )
oh and forgot to ask, do you want them to be LED? Cause that changes everything
Hmm well I would say no LEDs to keep the cost down , but I you find good and cheap white fans that have white LEDs I'm open for that
Btw, you can delete quotes by clicking on them and pressing delete.
1) NoiseBlocker e-Loop series is available at both 120 and 140mm. It comes in a black chassis with clear white fans (I actually have those on my x320x2 prestige radiator). The B12-P version offers 78 CFM/132.4m3h of airflow at 2000 RPM for 28 dBA. If you want less noise their B12-PS version will give you 58 CFM/98.7m3h at 1500 RPM for 21 dBA.
http://www.blacknoise.com/site/en/products/noiseblocker-it-fans/nb-eloop-series.php
2) BitFenix Spectre pro PWM is available at both 120 and 140mm. It comes in either all clear white or all greyish black. It offers 70.52 CFM/120m3h at 1800 RPM for 26 dBA.
https://www.bitfenix.com/global/en/products/accessories/spectre-pro-pwm#specs
3) Aerocool DS (for Dead Silent) is not PWM but it has 2 good setups and LED and looks pretty great too. You can run it on either 12V or 7V. The 12V cable will give you 81.5CFM/138m3h at 1500 RPM for 23 dBA. The 7V adapter will give you 62.5CFM/105.9m3h at 1100 RPM for an amazing 14.8 dBa.
http://www.aerocool.us/accessory/images/dsfan_12white.html
4) Noctua NF S12B redux comes in grey and offers you 59CFM/100.6m3h at 1200 RPM for 18 dBa. There is also a 140mm version (NF-P14s) running at 1200 RPM with 19.6 RPM.
http://noctua.at/en/products/product-line-redux/nf-s12b-redux-1200-pwm
5) Be Quiet! Silent Wings 3 offers a nice looking all black fan both in 120 and 140mm. The performance is relatively low, but the noise level is quiet. It offers 50.5CFM/80.47m3h at 1450 RPM for 16.4 dBA.
http://www.bequiet.com/en/casefans/722
If you want more suggestions I can give you some more
Thanks that's plenty of suggestion I'm sure I will find something
