Hi,
Here is my current part list: http://pcpartpicker.com/list/6bwXbj
I want the computer to be an overall good computer which can handle things like gaming, video editing, etc. I hope to in the future, when there is an update for the GTX 1070 for mac, to make the computer a dual boot with windows and macintosh, however, for now I would keep it all Windows. Any suggestions or compatibility issues would be appreciated.
Thanks.
https://linustechtips.com/topic/644572-first-build/
4 minutes ago, TechN00b said:
Hi,
Thanks.
Looks like a damn solid build to me. I would've gone 2 or 3 TB for gaming, because the 30 games in my steam library now takes up most of  my 1TB. Other than that, it looks  great. Good job :)
https://linustechtips.com/topic/644572-first-build/#findComment-8298604
Awesome, I will surely take that into consideration and probably upgrade to a 2 or 3TB (Better safe then sorry). Thanks!
https://linustechtips.com/topic/644572-first-build/#findComment-8298616
1 minute ago, TechN00b said:
Looking to spend less then $2000 on the build.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($319.99 @ Newegg)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($88.49 @ Newegg)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  ($147.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($84.99 @ Newegg)
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive  ($99.54 @ B&H)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.88 @ OutletPC)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card  ($629.99 @ SuperBiiz)
Case: Corsair 750D ATX Full Tower Case  ($154.72 @ B&H)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($80.98 @ Newegg)
Operating System: Microsoft Windows 10 Home Full - USB 32/64-bit  ($117.99 @ SuperBiiz)
Total: $1754.55
Generated by PCPartPicker 2016-08-16 22:31 EDT-0400
Overclock i7 please. And yes, that's a 1080.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/644572-first-build/#findComment-8298618
Just now, TechN00b said:
Less than $2000, but I won't mind the savings lol
Total: $1754.55
c:
USEFUL LINKS:
https://linustechtips.com/topic/644572-first-build/#findComment-8298623
Do you think its worth it going to the 1080, if so , I will surely go that route?
Worth it if you overclock that i7. Anything else will bottleneck it. If you want me to, I could edit the list and make it X99 c:
USEFUL LINKS:
https://linustechtips.com/topic/644572-first-build/#findComment-8298633
I think the problem with the X99 will be during the hackintosh part as that requires a greater knowledge of the process, which I currently don't have (First time). Thanks though!
https://linustechtips.com/topic/644572-first-build/#findComment-8298639
Get the build @TheRandomness sent you, and add an ASUS Xonar 7.1 sound card. You won't regret it. ;) Hope the build goes well!
https://linustechtips.com/topic/644572-first-build/#findComment-8298651
3 minutes ago, TechN00b said:
Awesome, thanks!
Sound cards aren't at all necessary but get one if the budget allows ;P
USEFUL LINKS:
https://linustechtips.com/topic/644572-first-build/#findComment-8298664
