Finding right cpu and gpu
Solved by HKZeroFive,
1 minute ago, NinjaMonkey2017 said:Its only 500 and i rather have a better cpu than it has gpu is not such a big deal at the time
The GPU is weak to be honest - a R7 240 isn't going to give much. Sure, it's a bigger hassle but it'll have much better performance for what you pay. $500 should net you a i3 6100 with a RX 480. If you were to invest the extra money intended for the CPU and GPU, you could have a much better build overall.
